[ENG] Issue - "Start/Stop" button greyed out
Pajamen
Hello, sorry to bother you guys.
I don't know what to do  my grey V8 car is installed in app, everything OK, but when I start "DRIVE", I can only switch headlights on and off. "Start engine" button is greyed out and I can do nothing about it.
Is there something I'm missing?
Thanks
Bearbeitet von Slot-Stop
Präfix+Tag "Totorial" entfernt
vor 2 Stunden schrieb Atomregen:
You can try to remove the car and adding it back.
Already reinstalled, removed car, added again, everything.
Still unable to start engine.
Phone-flip brake turned off, swapped engines multiple times, still nothing.
It must be something extremely silly ...
Hello,
I found the same problem with Start/Stop button. Did you already figure it out?
I tried everyting I could think of (reinstal app, different phone, older phone with older version of app, remove car and add it again, clean the inside of a car, dischare and charge the battery by using RC model charger) and still nothing.
Am 19.9.2025 um 20:11 schrieb THR3360:
When did you last drive?
My last drive was about 2 years ago and since then I am unable to drive with it. I waited for some updates of a car or app and still nothing.
Did someone figure it out?
vor 16 Stunden schrieb Louskacek:
Hello,
Pajaman hasn't driven the Dr!ft car in 5 years. He might not have updated the firmware. Unfortunately, even with the latest app version, the option to update the firmware with an Android phone hasn't returned. You absolutely have to use an iPhone for that... You haven't driven it in 2 years. I doubt the same assumption applies to you, but give it a try!
Android:
IPhone:
Am 6.12.2025 um 15:15 schrieb THR3360:
Yes, on my android phone I dont have option to update but my car has the latest update 1.73.0 from the past. So I tried it with iPhone anyway - found update, hit update, it updated and nothing happens...
I found in new app I can connect Xbox controler. So i tried it and when I press starting button on controler, the spedometer makes starting animation but rpms and speed drop to zero and I cant drive anyway.
vor 19 Stunden schrieb Louskacek:
I just fugure it out... if you want drive it you must change language in your phone to german 😀
Phone in my native language (czech):
Phone in german language:
Resetting the odometer is a serious crime in Germany... 🤣
Am 14.12.2025 um 19:53 schrieb Louskacek:
Thank you so much for the message. Please excuse the inconvenience. But great that you figure out that👍
Would you please be so kind as to send us this information, including which smartphone and operating system were used, to Service@sturmkind
Am 15.12.2025 um 15:44 schrieb THR3360:
In czech too, but it is common thing 😀
Am 16.12.2025 um 08:41 schrieb Martin:
Of course, I will sent it right now
  • Haha 2
